Deepak_Mehta
Feb 26, 2021Aspirant
Network Map Issue
Hi, I have 1 Main Orbi Router RBS 850 and 6 Satellite but in the map eveytime it show only 3 satellites? Can someone help me to how can i see all the orbi satellite in the Network map?
- Mar 03, 2021
Hi Deepak_Mehta
Chuck_M is right. The Orbi App Network map / topology view is limited to a maximum of 3 satellites. This is a design limitation. For you to check the list of Satellites, you may need to tap on "Tap here to see additional satellites"
Blanca
Community Team
Mar 02, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- Chuck_MMar 02, 2021Mentor
I may be mistaken, but I think there is a limit to the number of satellites you can see at one time.
I think the app is limited to displaying the router + 3 Satellites.
What happens when you tap on the "CLICK HERE TO SEE ADDITIONAL SATELLITES"
- Deepak_MehtaMar 02, 2021Aspirant
It shows all the devices, attaching the image for your reference.
- Blanca_OMar 03, 2021NETGEAR Employee Retired
Hi Deepak_Mehta
Blanca
Community Team- Chuck_MMar 03, 2021Mentor
Thanks Blanca_O, I was pretty certain that was the answer.
@Deepak_Mehta, please mark your post as solved.
Chuck
