Deepak_Mehta
Feb 26, 2021Aspirant
Network Map Issue
Hi, I have 1 Main Orbi Router RBS 850 and 6 Satellite but in the map eveytime it show only 3 satellites? Can someone help me to how can i see all the orbi satellite in the Network map?
- Mar 03, 2021
Hi Deepak_Mehta
Chuck_M is right. The Orbi App Network map / topology view is limited to a maximum of 3 satellites. This is a design limitation. For you to check the list of Satellites, you may need to tap on "Tap here to see additional satellites"
Blanca
Community Team
Chuck_M
Mar 02, 2021Mentor
I may be mistaken, but I think there is a limit to the number of satellites you can see at one time.
I think the app is limited to displaying the router + 3 Satellites.
What happens when you tap on the "CLICK HERE TO SEE ADDITIONAL SATELLITES"
Deepak_Mehta
Mar 02, 2021Aspirant
It shows all the devices, attaching the image for your reference.
