dona13
Apr 09, 2023Aspirant
Network map problem with RBK22 system
My system RBK22 with one router (RBR20 and one satellite RBS20) used to show in the network map the WIFI connected devices as well as my devices connected to the router or the satellite by wire (more...
- Apr 10, 2023
Ah ok. That explains it. Ya wouldn't be seen if that PC is off. LOL
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Apr 10, 2023Guru - Experienced User
Any progress since yesterday? Seen posts that this has been resolved for some users over night.
We reported these issues to NG yesterday...
dona13
Apr 10, 2023Aspirant
Hello, I have found what caused this problem, we may consider this fixed. Thank you.
- FURRYe38Apr 10, 2023Guru - Experienced User
And would you please tell us what you have found to have caused this problem?
- dona13Apr 10, 2023Aspirant
I certainly would, but everybody will laugh at me : the network wired computer that was missing from the picture was shut down. As soon as I turned it on and do a Refresh of the network map, it showed up !
Really. So one ethernet connected PC when OFF causes the Network map items to not appear.
Can you try this again with the PC shut off and produce this?
