dona13
Apr 09, 2023Aspirant
Network map problem with RBK22 system
My system RBK22 with one router (RBR20 and one satellite RBS20) used to show in the network map the WIFI connected devices as well as my devices connected to the router or the satellite by wire (more...
- Apr 10, 2023
Ah ok. That explains it. Ya wouldn't be seen if that PC is off. LOL
Glad you figured it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
dona13
Apr 10, 2023Aspirant
No, the network map was showing the devices that were connected to the WIFI, it was only the wired PC, which was OFF that did not show on the map. I am sorry if I did not explain it properly and my explanation created a misunderstanding.
Apr 10, 2023Guru - Experienced User
Enjoy. 📡
