voicekiller
Oct 22, 2021Aspirant
No satellites showing in iOS app, but showing in web interface
It was suggested by another user I post here. Orbi iOS app is no longer showing my satellites, but they are showing in the Orbi web interface. I have tried resyning. I have reset the satellites, b...
Oct 22, 2021Guru - Experienced User
If there showing on the web page then they should be seen in the Orbi app.
Have you tried removing the app, reboot our mobile device then re-install the app?
Try a different mobile device as well if you can.
- voicekillerOct 24, 2021Aspirant
FURRYe38 wrote:If there showing on the web page then they should be seen in the Orbi app.
Yes. I've removed and reinstalled on my phone with the same results. Also tested with an iPad running older software and the results are the same.
- FURRYe38Oct 26, 2021Guru - Experienced User
Try a reset on the RBR and RBS, setup with a wired PC as web browser. After setup was complete, the Orbi app showed the RBS.
