Toastrr
Jul 07, 2023Follower
Notification Message Quest Wifi Test Deep Link
I am receiving a notification message that reads, "Guest Wifi Test deep link". Does anyone know what this means?
- Jul 08, 2023
https://status.netgear.com/orbi
7th July 2023
Multiple Push Notifications
20 hours agoEarlier today, Orbi App users were sent multiple push notifications about guest WiFi. If you received one of these notifications, you can safely ignore it. The notifications were sent accidentally during an internal test. We apologize for any inconvenience.
Lon3Star
Jul 07, 2023Initiate
I also had this just happen, all were Guest WiFi Test Deep Link notifications, received 5 over a short period of time. Just turned off my Guest WiFi to be cautious
batmatt
I also turned off my guest wifi after getting these messages, but it did not make them stop. I suspect something in the mobile app.
- MinuetJul 07, 2023Initiate
I received the messages as well. My Guest WiFi is disabled. Does NetGear monitor community posts? Is there hope of receiving an explanation from NetGear on this?
- HobbitlauncherJul 07, 2023Initiate
IDK but hopefully they do. They decided to lock formal support behind a cancerous paywall. I submitted a ticket anyway, but this like that are what will push me to another brand if I can't get necessary support. I'm all for support/knowledge communities, but that shouldn't preclude actual support.
Fingers crossed we get an answer one way or another about this most recent issue soon.
- benrubJul 07, 2023Initiate
Thanks for replying everyone
I have no idea if this is related, but the "device manager" in the Orbi app is showing me that there are "no connected devices found". Very strange. My internet access however, seems to be normal.
- WireDawgJul 07, 2023Aspirant
Same for me. I tried each Orbi satellite/router individually and that then indicated the connected devices.
