Toastrr
Jul 07, 2023Follower
Notification Message Quest Wifi Test Deep Link
I am receiving a notification message that reads, "Guest Wifi Test deep link". Does anyone know what this means?
- Jul 08, 2023
https://status.netgear.com/orbi
7th July 2023
Multiple Push Notifications
20 hours agoEarlier today, Orbi App users were sent multiple push notifications about guest WiFi. If you received one of these notifications, you can safely ignore it. The notifications were sent accidentally during an internal test. We apologize for any inconvenience.
GME2
Jul 07, 2023Aspirant
Today I've received on my Orbi app these five notifications: "Guest WiFi PN Guest WiFi Test deep link." I've never rec'd this notification before and don't understand it. There's also a box "Unable to Connect to Router." My devices are connected to the Orbi router, so I don't know what is "unable to connect to router." Also, the Guest WiFi setting is off; I don't recall ever using the guest wifi nor do I have a guest wifi password. (This situation may be completely unrelated, but recently, I've notice that when I return home, my smart phone often does not automatically reconnect to the Orbi router. It's staying connected to a random Xfinity connection (my Internet provider), even though the Orbi router is has a much better signal. I have to manually connect the phone to the Orbi router. Again, this is new problem.) Thank you for your assistance in diagnosing this problem. Gregg
