Toastrr
Jul 07, 2023Follower
Notification Message Quest Wifi Test Deep Link
I am receiving a notification message that reads, "Guest Wifi Test deep link". Does anyone know what this means?
- Jul 08, 2023
https://status.netgear.com/orbi
7th July 2023
Multiple Push Notifications
20 hours agoEarlier today, Orbi App users were sent multiple push notifications about guest WiFi. If you received one of these notifications, you can safely ignore it. The notifications were sent accidentally during an internal test. We apologize for any inconvenience.
StefMcDuff
Jul 07, 2023Aspirant
A deep link is an application term. A deep link will (essentially) take you directly to an app instead of a webpage. Think of if you search "Facebook" on your android phone in Google how you can click the result and it takes you to the Facebook app.
Appears that they were testing a deep link to the guest wifi page in the application. Probably shouldn't have been testing in prod, but I think that the notifications are innocuous (and hey, they worked! Opened straight to the guest wifi page in the app.)
- Polyh3dronJul 07, 2023Aspirant
I'm also getting spammed with these notifications all of a sudden today while I'm offsite, and I don't even have an active guest network. My app isn't allowing me to log in either, giving me an error that doesn't say my credentials are incorrect, suggesting more of a failure on the server end of things for this app.
- FURRYe38Jul 07, 2023Guru - Experienced User
NG is already aware of the issues at hand.
If you are having problems logging in, please submit a bug report:
Thank you.
- MosesChanJul 07, 2023InitiateI agree with you that netgear probably conduct testing in wrong environments because all case is reported these 2 day. I am not an experienced app developer but I guest they broadcast the testing message by their notifications server with wrong target group i.e production group, which should be intended be targeted to SIT or UAT devices .
