KVG75
Sep 08, 2022Aspirant
On which phones are circle installed
Hi, Is there a way to find out on which phones the circle app has been installed? It seems that the settings are changed by someone else other than myself. Is there a way to block other devices...
michaelkenward
Sep 12, 2022Guru - Experienced User
KVG75 wrote:
Is there a way to find out on which phones the circle app has been installed? It seems that the settings are changed by someone else other than myself. Is there a way to block other devices using the circle app?
Try your question here:
Circle Smart Parental Controls - NETGEAR Communities
- KVG75Sep 12, 2022Aspirant
Hi Michael,
Thanks for that! Will do.
Cheers,K
