jonmck
Feb 23, 2022Aspirant
One of three satellites repeatedly showing a TON of times on firmware upgrade page.....WHY?
Within the app, it is no longer showing my three satellites. It only shows the router. When I login to the web admin panel, and click on attached devices, it DOES show the three satellites there. H...
Feb 26, 2022Guru - Experienced User
Try a factory reset on the RBS and RBR and setup from scratch.
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi (WiFi5 RBK10, 20, 30, 40 and 50 Series). Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
jonmck
Feb 26, 2022Aspirant
Thanks! That worked....I did a factory reset and setup from scratch.
