Tekk
Apr 29, 2023Tutor
Orbi 6E satellites working but not showing up
I set up a new Orbi 6E system with 3 satellites. It was working perfect. Web interface, app, everything. Now it is behaving very strange. The app shows no satellites. Not disconnected. Just ...
- May 01, 2023
Sounds like you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Tekk
Apr 29, 2023Tutor
Actually need to add this info. I have probably 70 devices connected. All working. But the web interface and the app only show devices connected to the main router. Anything connected to the satellites are not showing up but are working. Perplexing.
