Petie53
Dec 15, 2022Aspirant
Orbi 853 not displaying connected devices
New RBK853 installed and working. Don’t understand why it doesn’t want to show most of the wired connection devices in the app. I had deleted some devices that I converted from wireless to wired conn...
Dec 16, 2022Guru - Experienced User
1. what modem/gateway is it connected to?
2. what firmware is on the router and the satelilites?
3. does it display properly if you log in through the browser?
Petie53
Dec 16, 2022Aspirant
I have done a total reset of Omni 853. It shows most of the devices attached to one satellite but none of the 4 devices direct wired on the other satellite.
Omni 850 Firmware V4.6.14.3
Netgear cable modem CM2000
Have not tried using browser yet.
- Petie53Dec 16, 2022Aspirant
Ok just used browser and it shows the same attached devices as the app does.
Guess it isn’t a problem as everything works and all devices can access the internet but weird the device listing is so screwed up.- Petie53Dec 17, 2022Aspirant
Well NETGEAR says they are doing maintenance on the app. Sounds weird but ok. Thankfully the modem and router function really well. Bye for now.
