DannoUK
Oct 08, 2020Aspirant
Orbi Android App Connection Issue
Hi everyone, I've just picked up the Orbi RBK53 pack and am having some issues with the Android App. I set up the RBK50 and satellites using my laptop and all is working ok after quite a few tee...
- Oct 16, 2020
Hi all,
I've figured out this was caused by have dns.adguard.com enabled as a private DNS on my Android phone. Disabling this solved me issue.
Regards
Dan
Christian_R
Oct 13, 2020NETGEAR Employee Retired
Hi DannoUK,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
DannoUK
Oct 15, 2020Aspirant
Hi Christian,
I bought the device off eBay so it isn't new.
It seems that others have had this issue a couple of years back with no resolution. Does anyone know if the Orbi app works when the router is in AP Mode and if the default IP address has been changed from 192.168.1.1 to something else?
Regards
Dan
- DannoUKOct 16, 2020Aspirant
Hi all,
Regards
Dan
