Ferrellt
Nov 28, 2022Star
Orbi anywhere access architecture
Is there any documentation available on how the Orbi anywhere access app works? If I had some basic understanding of this I could probably solve my own problem with anywhere access. For example, Netge...
CrimpOn
Nov 29, 2022Guru - Experienced User
Ferrellt wrote:
Seems it would be easy enough (for now) to have.....
That is indeed a good question. One of the surprising differences between Apple iOS and Android is the capability to interact with the "lower levels" of the operating system. For example, Android users have their choice of numerous apps that display graphs of WiFi signal levels, which APs are on which channels, etc. My understanding is that Apple does not allow developers the same degree of access to system fundamentals. (Although I understand very little about "Apple things".)
"Something went wrong" just seems lame.
Ferrellt
Nov 29, 2022Star
IOS generally doesn't allow free reign to OS internals the way Android does, but still, there's got to be some kind of error or return code from something that could be displayed. In most of the programming environments I have worked in,a filure returns a non-zero error code or something similar..
