docml
Sep 25, 2020Aspirant
Orbi Anywhere Access cloning
I am lucky enough to have two homes (let's call then Home A and Home B). Each has an Orbi network consisting of a base RBR50 unit and then various satelittes. Home A had Anywhere Access enabl...
Mstrbig
Sep 25, 2020Master
If the app does not give you the option to switch between A and B, In order to do that you will need 2 separate accounts.
docml
Thanks MstrBig I assume that means that I have now lost all access to Home A until I can get back to Home A to reset everything? I still don't understand how it managed to reset all of Home A remotely, but now there's no way of accessing Home A remotely. But your feedback is much appreciated.
- CrimpOnSep 25, 2020Guru - Experienced User
Having only one Orbi system, I have not done this myself BUT...
On the Home menu (pictue of house), there is an entry "New Setup". I seem to remember reading a post that said using that would create a second system in the account. How did you install the second system?
p.s. Questions about the Orbi "app" may get a more informed response if posted in the community forum for the app:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
People who watch that forum obviously have a pretty strong interest in the app and may have more experience with it.
- MstrbigSep 25, 2020Master
CrimpOn wrote:Having only one Orbi system, I have not done this myself BUT...
That's correct, the new setup is for setting up a second new Orbi system.
I'm confused as to why both systems are not showing up in his app, if the OP added a second system. My app shows 2 systems.
