Isnt
Oct 31, 2020Star
Orbi App Bug with Firmware 2.7.1.60
I updated to Orbi firmware 2.7.1.60 last night and now when I go to view the devices connected to the Orbi via the Orbi app I get the following error. This happens on both my iPad and iPhone so it se...
- Dec 13, 2020
Solved for me at least!
I downloaded to newest iphone app this morning and I can now access the Device Manager and see all devices with no error occurring! So finally fixed I think. I tried it both on my iphone and ipad and it works fine :-D I hope it's fixed for everyone now!
RobertHardy
Nov 01, 2020Aspirant
Having the same problem after firmware upgrade. Cannot see list of devices.
Nov 01, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- IsntNov 02, 2020Star
I've posted here meanwhile:
https://community.netgear.com/t5/Orbi-App/Orbi-App-Bug-with-Firmware-2-7-1-60/m-p/2000585#M2314
Seems like this error has been happening to a number of people.
I also noticed this error occurs for people with newer firmwares on Nighthawk routers as well and using the nighthawk app. I think it is a firmware issue.
- FURRYe38Nov 02, 2020Guru - Experienced User
Something NG will have to look into. Nothing we can do about it here in the forums. Keep in touch with NG support.
Good Luck.- Stev3DNov 05, 2020Luminary
FURRYe38 if you have any pull with Netgear (and I suspect you do), please alert them to other issues that the v2.7.1.60 update created. Not only is there an issue with the app, but MAC address filtering ("Access Control") has gone haywire (again -- a lot like what happened a year ago). Unfortunately, it only takes a zillion posts on the Community before they notice, so if you can speed up the process, please do.
