Isnt
Oct 31, 2020Star
Orbi App Bug with Firmware 2.7.1.60
I updated to Orbi firmware 2.7.1.60 last night and now when I go to view the devices connected to the Orbi via the Orbi app I get the following error. This happens on both my iPad and iPhone so it se...
- Dec 13, 2020
Solved for me at least!
I downloaded to newest iphone app this morning and I can now access the Device Manager and see all devices with no error occurring! So finally fixed I think. I tried it both on my iphone and ipad and it works fine :-D I hope it's fixed for everyone now!
Isnt
Dec 14, 2020Star
So, as some have mentioned, it might be Netgear Armor that is breaking it. Coincidentally my Netgear Armor expired a few days ago. So perhaps the fact that it is expired might have been the real fix for me.
slapshot2213
Dec 14, 2020Aspirant
Nothing has changed for me using Android. Also, I've never activated/used Armor. The issue started after the firmware upgrade. Likely unrelated, but my VOIP phone has been experiencing a lot more "dropouts" since the firmware update.
- ase116Dec 15, 2020Aspirant
I have found a solution re:Orbi iOS app not working with the new firmware update V2.7.1.60 I manually changed to the firmware V2.6.1.40. You can find it on the link: kb.netgear.com/000062484/RBR50-RBR50-Firmwar-Version-2-6-1-40 You also have to delete the Orbi app from your iPhone, then reinstall before connecting to the router after the firmware change. I have seen posts that the app worked only for a short time after the update to V2.7.1.60, but I have not had that problem. Changing to V2.6.1.40 does NOT seem to have the conflict with the iOS Orbi app. Hope it works for you!
