Isnt
Oct 31, 2020Star
Orbi App Bug with Firmware 2.7.1.60
I updated to Orbi firmware 2.7.1.60 last night and now when I go to view the devices connected to the Orbi via the Orbi app I get the following error. This happens on both my iPad and iPhone so it se...
- Dec 13, 2020
Solved for me at least!
I downloaded to newest iphone app this morning and I can now access the Device Manager and see all devices with no error occurring! So finally fixed I think. I tried it both on my iphone and ipad and it works fine :-D I hope it's fixed for everyone now!
Kdillon120
Dec 27, 2020Aspirant
It would appear Netgear somehow addressed the situation. I did nothing to fix the problem of devices not being listed in the Orbi app, so I assume Netgear addressed it through an automatic firmware update. we'll see for how long.
dep14
Jan 02, 2021Aspirant
I have an Orbi Mesh Network system I purchased from Costco back in August.
The network, and the app worked flawlessly until late October.
In late October, when both IoS and the Orbi App was updated, I lost all use of the App. A system reset, with re-naming the network and starting from scratch got things working again.
The app worked well for a couple of weeks. Now, it works for about 24-36 hours and the App quits working and says it can't find the network. (same issue as before).
However, if I unplug and re-plug in my main Orbi router, it does seem to also reset the app. So, at least it's a work-around, but it is pretty annoying. Any thoughts?
App is version 2.7.4.1.
IoS - 14.2
Thanks.
- ase116Jan 02, 2021Aspirant
See my previous posting dated 12-15-20, message 38/54. If you are having problems with the iPhone Orbi app working after upgrading to Firmware 2.7.1.60 to the base router RBR50, I would recommend manually changing the firmware back to the previous version. There is a new beta version that corrects the problem, but until it is available, using the previous firmware 2.6.1.40 works. Contact Christian (post of 12-21-20) for more information.
- dep14Jan 02, 2021Aspirant
I have version 2.7.4.1... I assume that is another new one?
Is there a 2.6.4.1 that I likely used to have?
Again, what is weird if I unplug and plug my router back in the app seems to work again...
Yes, the 2.6.1.40 is the previous version. You can download this firmware version to your computer using the link in my 12-15-20 posting. Manually change the firmware in Advanced Settings/Administration in the router's Configuration Utility.
