RHE42
Aug 14, 2024Aspirant
Orbi App Connected Devices - Network
Using latest Orbi App version with RBR750 plus 2 RBS750 satellites. Experiencing slow WiFi performance. Trying to remove all unused "Devices" from the WiFi network using the App. I show three "networ...
- Aug 16, 2024
What Fw version is loaded on the Orbi system?
Yes you can remove devices if there in a grayed out status from the Orbi app. Just means there no longer connected or seen by the app. If you have them and re-connect them at a later point, then they will return and be seen by the app.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageAlso seen in newer versions of Windows OS.
RHE42 wrote:
Using latest Orbi App version with RBR750 plus 2 RBS750 satellites. Experiencing slow WiFi performance. Trying to remove all unused "Devices" from the WiFi network using the App. I show three "networks" listed as devices with names like DA16200_58D8 and two others. As far as I know, there are no "networks" connected to my Orbi WiFi that I am aware of. I'm afraid to delete them for fear of the results! What are these "networks" and can I safely delete them?
RHE42
Aug 15, 2024Aspirant
Thank you CrimpOn for your response.I have cleaned up many many not connected devices on the App Device List. System seems to be working better and more smoothly. Still not sure of the "Network" entries on the list. If it's not the 'not connected' devices slowing the wifi down, can you say why the mesh wifi network slows down to the point of making watching TV very frustrating while at the same time my incoming StarLink internet connection tests above 75mbps? Thank you for your time.
RHE42
I have the screen shot you requested but I can't figure out how to send it to you. Help?
- CrimpOnAug 15, 2024Guru - Experienced User
I "cut and paste" into the message.
- RHE42Aug 15, 2024Aspirant
Thanks again. Here is the screen shot showing the networks.
Thanks for posting the screen shot. Those two devices are very likely mobile devices which are using a randomized MAC address rather than their hardware MAC address. This is a feature of recent Apple and Android software which is intended to allay fears that "Big Brother" might track where a person has been based on the device connecting to WiFi hot spots. See, for example:
https://support.apple.com/guide/security/wi-fi-privacy-secb9cb3140c/web
https://source.android.com/docs/core/connect/wifi-mac-randomization-behavior
Because of this, the software feature used by the Orbi firmware to identify products based on their MAC address fails. (Also, attempts to reserve IP addresses for devices based on MAC address also get messed up.)
In this case, the Orbi app has defaulted to the term "Network" to describe the device.
A careful examination of the MAC address will probably show it to be very similar to a mobile device that is actually on the network, but which does not appear on the list of connected devices.
Could you please go through the entire list and determine if any devices are missing and have similar MAC addresses?
My first attempt to proceed as you suggested revealed this interesting issue. On the app on my iphone there are listed 27 devices "connected". Of those, 18 have a green dot on the left of the device "name" indicating (I think) they are connected right now to the WiFi. That leaves 9 devices with a gray dot indicating not connected right now. Note this adds up: 18 + 9 = 27. Now I opened the Device listing on the wifi router on my computer (mac) and this list shows 16 devices (with no green or gray indication) plus two satellite Orbi's. Note 16 + 2 = 18 which the same as the number of devices indicated with green dot on my iphone. None of the connected devices shown with a gray dot on my iphone are shown on the device list for the router on my computer. Does this make sense to you ? Am I in good shape even if I don't know it?
