sjschmidtky1
May 18, 2022Guide
Orbi app doesn’t recognize anything
It’s been many months since I opened my orbi app. It’s not recognizing any of my equipment, but it appears to be working fine. When I try to add again, it wants me to connect to ORBI71 network, but I ...
May 19, 2022Guru - Experienced User
There's an issue with the orbi app. Theres a notice in the orbi ax forum about it if you have the AX version.
Tough to know as you didn't put it in your post which one you have.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
If you have the ax version, try a factory reset and reinstall using the browser and not app.
sjschmidtky1
May 20, 2022Guide
Hi,
sorry, should have mentioned that I have AX6000 (with satellite) aka RBR850. That help any?
Thanks!
- plemansMay 20, 2022Guru - Experienced User
Its that same app issue. You'll see a note at the top of the AX forum about issues with the app.
Sounds like theres a fix in the works if you want to wait. Otherwise you try the factory reset/reinstall
- sjschmidtky1May 20, 2022Guide
Thanks, I’ll just wait. After all, I’ve not used the app for months until my recent try.
thanks, Steve
