BretD
Mar 30, 2018Administrator
Orbi App, Easily Setup, Control and Monitor your Orbi Whole Home WiFi
Do you have the Orbi App?
The NETGEAR Orbi app makes it easy to set up and personalize your Orbi WiFi System. With the app, you can install your mesh system in few steps - just connect your...
Paulleyva1977
Mar 31, 2018Aspirant
I have the satellite in my room n my Xbox1x is hooked up to it thru WiFi. Can I or should I just run a Ethernet cord from the satellite to my Xbox?. And can I tell some how if their is a good clean connection between the router n the satellite.??
Apr 01, 2018Guru - Experienced User
Yes, you can ethernet connect the xbox to the satellite.
Check Connected Devcies on the routers web page for status of signal of the Satellite connection. You can check the status as well form the satellites web page as well.
