BretD
Mar 30, 2018Administrator
Orbi App, Easily Setup, Control and Monitor your Orbi Whole Home WiFi
Do you have the Orbi App?
The NETGEAR Orbi app makes it easy to set up and personalize your Orbi WiFi System. With the app, you can install your mesh system in few steps - just connect your...
Chemo29
Apr 03, 2018Guide
You should add this disclaimer:
However, the app will only work intermittently, if ever, because your ORBI will keep dropping the Wifi and internet connection.
- aazApr 03, 2018Virtuoso
Chemo29wrote:You should add this disclaimer:
This has not been true for me. The Orbi has been more stable than any other router I've had in the past 15 years. I know it's sarcasm, but it's only true for a minority of users on here that the Orbi has been unstable for some unknown reason most likely due to environment.
- AniDuttaApr 04, 2018ApprenticeOrbi app is useless in AP mode. Why can't the app have the functionality to pause internet in AP mode? Even Circle doesn't work on AP mode.
- budyApr 05, 2018Luminary
AniDuttawrote:
Orbi app is useless in AP mode. Why can't the app have the functionality to pause internet in AP mode? Even Circle doesn't work on AP mode.This has to be expected. To perform any kind of traffic inspection or filtering, the Orbi has to become a router. You can setup your Orbi like that, but then you would have all your devices - and this includes the wired ones, to be connected to the Orbi system.
This would also introduce double-NAT into your network, which will give you some headaches with UPnP since the actual router in front of your Orbi, which would also need to act on UPnP wouldn't know that.
So un less you can't - or don't want, to exchange your internet facing router with the Orbi router, you will have to let go of the Circles app and use the Orbi just as what it can provide in AP mode.
