BretD
Mar 30, 2018Administrator
Orbi App, Easily Setup, Control and Monitor your Orbi Whole Home WiFi
Do you have the Orbi App?
The NETGEAR Orbi app makes it easy to set up and personalize your Orbi WiFi System. With the app, you can install your mesh system in few steps - just connect your...
Apr 05, 2018Guru - Experienced User
If you have a different router ahead of the Orbi router and want to run the Orbi router in Router Mode and take advantage of the app features, I recommend configuring the 1st routers DMZ for the IP address the Orbi router gets from the 1st router. Input this IP address into the 1st routers DMZ. This will help with a double NAT condition, then configure your Orbi router for Router mode, then you should be able to take more advantage of the app features.
AniDuttawrote:
Orbi app is useless in AP mode. Why can't the app have the functionality to pause internet in AP mode? Even Circle doesn't work on AP mode.
TTTraylor
Apr 11, 2018Aspirant
Regarding the Orbi App for iPhone, all functions seem to work fine for me EXCEPT, the speed test was working great when first installed. Now that function continues to notify me CONNECTION FAILED, even though I have a strong connection, confirmed by my external and separate speed test ap. Hasn't worked since Day One. Anyone else have that issue or a solution?
Thanks.
- SeattleericApr 11, 2018InitiateI have exactly the same issue as TTTraylor. I was able to test speed for two days now I get Connection Failed message even though I have connectivity. I’ve tried rebooting the router and it has not helped.
- Retired_MemberApr 12, 2018
Same here.
- do33grsApr 12, 2018AspirantSpeed test fails here as well. Just set up system today.
