GSBALAJI
Aug 19, 2021Aspirant
ORBI APP HOW TO CONNECT 2 PHONES
Hello all I had downloaded the ORBI app and using for my RBK50 mesh router, I want to use the same app for my wife's phone also, both of us having apple I phone. Plese let me know is it possible? ...
CrimpOn
Aug 19, 2021Guru - Experienced User
I have the Orbi app installed on four different Android devices ( two phones, two tablets). As far as I know, there is no limit to the number of devices that can run the Orbi app and manage one Orbi system.
GSBALAJI
CrimpOn Thanks for the info, If possible can you please let me know how to do, because I have tried the 2nd phone and enter the same username and password, after this message shows that not connetced , ask me 2 options start setup again or tryagain
So I dont know what to do
Thanks
- CrimpOnAug 20, 2021Guru - Experienced User
Thanks
I do not know if there is a difference betweeen Apple and Android in setting up the app. All I do is enter my Netgear user ID and password and Login. Of course, the phone has to be connected to the Orbi WiFi network at the time in order to find the router.
