LEPhil
Sep 04, 2021Aspirant
Orbi App issues
RBR750 RBS750 x 2 Firmware version V3.2.16.22 iPhone 11 pro software 14.4 Bought and installed the Orbi Wifi 6 today. The app has not worked at all. It only recognized the RBR once and th...
Sep 05, 2021Guru - Experienced User
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact Blanca_O and DarrenM and send them a PM and ask for the beta.
Good Luck.
LEPhil
Sep 06, 2021Aspirant
Thanks.
Yes. Setting up the app and installing the AX4200 system with the app proved impossible. I was able to setup the system manually and then after numerous re-boots of the iPhone, I was able to get the app to catchup. Someone with less network experience would have returned the product.
- FURRYe38Sep 06, 2021Guru - Experienced User
Glad you got it set up manually.
Please mark your thread as solved so others will know.
Enjoy.
