LEPhil
Sep 04, 2021Aspirant
Orbi App issues
RBR750 RBS750 x 2 Firmware version V3.2.16.22 iPhone 11 pro software 14.4 Bought and installed the Orbi Wifi 6 today. The app has not worked at all. It only recognized the RBR once and th...
LEPhil
Sep 06, 2021Aspirant
Thanks.
Yes. Setting up the app and installing the AX4200 system with the app proved impossible. I was able to setup the system manually and then after numerous re-boots of the iPhone, I was able to get the app to catchup. Someone with less network experience would have returned the product.
Sep 06, 2021Guru - Experienced User
Glad you got it set up manually.
Please mark your thread as solved so others will know.
Enjoy.
