JPSantelli
Jun 11, 2022Follower
Orbi App loses configuration of second home Orbi system
My RBR850 system (router +2 satellites) has been working since installation a year ago. The Orbi App had no trouble connecting to the system. This winter I installed another RBR850 system in another ...
- Jun 13, 2022
Hello JPSantelli,
I understand that you have two different mesh systems you would like to be connected to your Orbi app. Both systems are connected to your Orbi app. However, there are times in which you may have to manually select the system that you are trying to connect to in the Orbi app.
Please try the following steps to resolve this issue:
- Navigate to Orbi app
- From the home page
- Select the Cloud icon on the upper left.
- Then select the second cloud icon on the upper left above the settings option.
- Now select the desired RBR850
Best,
Kevin
Community Team
KevinLiT
Jun 13, 2022NETGEAR Moderator
Hello JPSantelli,
Best,
Kevin
Community Team
- santelliJun 14, 2022Tutor
Kevin -
Thank you for your suggestion. I did the factory reset and ti seems to have worked for now. I will be curious to open the Orbi app when I get back to my other house.
Jim
