sujguru
May 12, 2022Aspirant
orbi app not able to connect to orbit router
Orbi router had power disconnect; subsequently, orbi router came back and works fine and connected to my wifi. Whereas orbi app is not able to connect to orbit router; it says mobile wifi to be conn...
May 12, 2022Guru - Experienced User
- sujguruMay 13, 2022Aspirant
None of this resolves the problem. Given what I heard from support that orbi app has bug and being patched, I waited and updated. Still same problem. Thanks for your response though.
- MasakiKoiMay 13, 2022Star
Netgear if you are reading this.....The new Orbi app update for the iPhone last night 5/12/22 did NOT solve the problem!!!!. Orbi app version 2.17.0.171. App still not able to connect to router.
Error message......"We can't find your Orbi". Fix it please!!!
