sujguru
May 12, 2022Aspirant
orbi app not able to connect to orbit router
Orbi router had power disconnect; subsequently, orbi router came back and works fine and connected to my wifi. Whereas orbi app is not able to connect to orbit router; it says mobile wifi to be conn...
May 13, 2022Guru - Experienced User
- sujguruMay 13, 2022Aspirant
Thanks for the pointers. I tried couple of times before and this time it worked fine. Problem is resolved. Thanks again for your inputs.
On the other hand, this is reasonably bad that a simple problem could not be fixed in a simple way rather a hard way resetting hardware, just like anything and everything 🙂
- FURRYe38May 13, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
