Ozonshak
May 15, 2022Star
Orbi app not connecting and not finding router
Hello. Not sure when this started happening, but my Orbi RBR750 is no longer connecting to the app. Getting “unable to detect WiFi” error. Web page is not working either. I tried reinstalling the app,...
May 16, 2022Guru - Experienced User
- OzonshakMay 16, 2022Star
FURRYe38 Thanks for the link. I actually mentioned that link in my original post, so already aware. However, that solution is a full factory reset. Do you have any updates on a solution that doesn't require a reset? I have a TON of settings I really don't want to setup all over again, including parental controls.
- FURRYe38May 16, 2022Guru - Experienced User
Get in contact with ChristineT and send her a PM with your RBRs serial number and email address you use for NG account info.
I believe there pushing a patch for users to avoid a reset.
No idea when she will respond. She's been busy lately.
IF and when you regain access, be sure to save off a back up configuration to file. Saves time IF a reset is needed.
- DarrenMMay 17, 2022Sr. NETGEAR Moderator
Please discuss this issue in this thread. https://community.netgear.com/t5/Orbi-App/RBR850-We-can-t-find-your-Orbi/m-p/2220651/highlight/true
Thanks
DarrenM
