DustinG
Nov 10, 2020Aspirant
Orbi App Not Connecting even on Wifi
I've been having this issue for quite some time now where I need to delete the Orbi App and reinstall it in order for me to get into the Orbi settings from the Orbi App, even though I'm on the same W...
Christian_R
Nov 16, 2020NETGEAR Employee Retired
Hi DustinG,
May you provide us with the model number of your router and current firmware version its on? I would also recommend updating to iOS 14.2 if you haven't done so already.
Christian
- DustinGNov 16, 2020Aspirant
ProductOrbi AC2200 Tri-band WiFi System(CBR40)
Serial
Number5AK1857RA04E0
I believe the firmware version is 2.7.0.28?
That is what it shows at teh bottom of the app when "Detecting Product" is on the screenApple iOS software is 14.1 but I do not see an option to upgrade as it says "Your software is up to date"
I reinstalled this app last week, worked fine for a week and now is having trouble connecting
Thank you,
Dustin- Christian_RNov 17, 2020NETGEAR Employee Retired
Hi Dustin,
Thanks for the info. May you reinstall the Orbi app again and check to see what version installs and provide the version number to me. I would also recommend rebooting your phone to check for the iOS 14.2 update.
Regards,Christian
- DustinGNov 17, 2020AspirantTried that. No luck being able to sign into the app.
