DustinG
Nov 10, 2020Aspirant
Orbi App Not Connecting even on Wifi
I've been having this issue for quite some time now where I need to delete the Orbi App and reinstall it in order for me to get into the Orbi settings from the Orbi App, even though I'm on the same W...
DustinG
Nov 16, 2020Aspirant
| Orbi AC2200 Tri-band WiFi System(CBR40) | Serial | 5AK1857RA04E0 |
I believe the firmware version is 2.7.0.28?
That is what it shows at teh bottom of the app when "Detecting Product" is on the screen
Apple iOS software is 14.1 but I do not see an option to upgrade as it says "Your software is up to date"
I reinstalled this app last week, worked fine for a week and now is having trouble connecting
Thank you,
Dustin
Christian_R
Nov 17, 2020NETGEAR Employee Retired
Hi Dustin,
Thanks for the info. May you reinstall the Orbi app again and check to see what version installs and provide the version number to me. I would also recommend rebooting your phone to check for the iOS 14.2 update.
Christian
- DustinGNov 17, 2020AspirantTried that. No luck being able to sign into the app.
- Christian_RNov 18, 2020NETGEAR Employee Retired
Hi DustinG,
Thanks for confirming. May you also check to see if you have local network access enabled. The article below will guide you on how to enable the local network access. You may also reboot your iPhone and check to see if iOS 14.2 is available for update.
Christian
- DustinGNov 18, 2020Aspirant
I was able to update to iOS 14.2
Yes, the enable local network has been enabled
Deleted and re-installed 3 times today, no luck still
Thank you
Dustin
