Iamloeky
Jun 30, 2021Aspirant
Orbi app not connecting to WiFi after install
iOS app has been removed and reinstalled. App doesn’t find WiFi nor the device after successful installation of new router and satellites. Have used with previous system without issue. WiFi i...
Christian_R
Jul 07, 2021NETGEAR Employee Retired
Hi Iamloeky,
May you reinstall the Orbi app as we recently released v2.10.5.17 for iOS.
Christian
edazed
Jul 14, 2021Aspirant
I am having this EXACT same problem. I purchased my Orbi and satellites on 7/7/21 and downloaded the app on 7/9/21. Now you are saying we should download the app again? My app IS 2.10.5.17.
- FURRYe38Jul 15, 2021Guru - Experienced User
Try removing the app then re-installing the app...
Try installing the app on a different device...
edazed wrote:I am having this EXACT same problem. I purchased my Orbi and satellites on 7/7/21 and downloaded the app on 7/9/21. Now you are saying we should download the app again? My app IS 2.10.5.17.
- edazedJul 15, 2021Aspirant
Thanks, I talked to a nice person at NetGear support. They had me power down the Orbi router and then we tried several times to do orbilogin.net and entering in the IP address to a browser, etc., etc. Then she had me, several times, try to re-set my Orbi router admin password. The admin password never re-set, but magically, my old password worked on the app and I can now use the app.
None of this made any sense as to the instructions I was being given, but, who cares, the app works now. So, sprinkle a little fairy dust and do some hoodoo incantations, and maybe it will work like mine did. Still should have worked from the get-go, but I am grateful to Netgear support for helping me fix my problem (though I still can't tell you what fixed the problem).
PS: I CAN tell you that about the only thing I did different was switch from trying to use my desktop (for the IP, etc.) and my iPhone to trying to do all this on my iPad. Don't know if that was the key, but the suggestion to try a different device may be valid.
- FURRYe38Jul 16, 2021Guru - Experienced User
Glad something started working.
Be aware that there is a new FW version of Orbi 7 series systems.
edazed wrote:Thanks, I talked to a nice person at NetGear support. They had me power down the Orbi router and then we tried several times to do orbilogin.net and entering in the IP address to a browser, etc., etc. Then she had me, several times, try to re-set my Orbi router admin password. The admin password never re-set, but magically, my old password worked on the app and I can now use the app.
