DmLondon
Feb 16, 2022Aspirant
ORBI app not showing correct info (satellites & connected devices)
Hi, after numerous problems with an RBK753 set up. (Never buying netgear again!) I feel I finally may have ‘some’ stability BUT THE APP…. My system is working fine touch wood but the app, more spec...
Feb 17, 2022Guru - Experienced User
Can you post a screen shot of what yoru seeing with in the Orbi app?
What FW is loaded on the Orbi system?
Try a different mobile device to install Orbi app on and compare results...
