veacomp
Jan 17, 2025Aspirant
Orbi app not showing offline devices.
I recently purchased an Orbi 772 system and noticed with the latest app update that the Devices screen no longer shows offline devices so I can delete them. They also don't show in the web portal but...
CrimpOn
Jan 17, 2025Guru - Experienced User
Does the web portal have the Security Menu, Access Control. On older Orbi routers, there are tables of devices that are not connected. If Access Control is enabled, those tables can be cleared.
- veacompJan 17, 2025Aspirant
It does not. There is a Security tab but when you go in there, it has a message pointing to the app which only shows online devices.
- CrimpOnJan 17, 2025Guru - Experienced User
How strange. The user manual on pages 50-51 shows the Access Control page as having these tables:
https://www.downloads.netgear.com/files/GDC/RBE773/RBE771_RBE770_UM.pdf
Are Smart Parental Controls (SPC) enabled on this system?
- veacompJan 18, 2025AspirantThey are not but on the iPad version of the app, the UI isn’t updated and I can view and delete on that view. I am guessing the iPad app hasn’t yet been updated.
