pgbauer
Apr 15, 2020Initiate
Orbi App Remote Management Not Enabling
Hi, eveytime I go into my Orbi App on my iPhone and go to settings to enable remote management - when I move the slider it then comes up with a error message that states "Something went wrong, sorry ...
Christian_R
Apr 17, 2020NETGEAR Employee Retired
Hi pgbauer,
After setting up remote management, you can move forward with setting up remote access on the Orbi app. I have linked an article for directions.
https://kb.netgear.com/000058240/How-do-I-enable-or-disable-remote-access-on-my-Orbi-router
Christian
mrjmartin
Jun 02, 2020Aspirant
Unfortunately, there doesn't seem to be an option for the model: SRR60. I'm also having this issue, and it's occurred for the past several months. Thought it was firewall related, but it seems it isn't. Any recommendations at all? I've already enabled the remote management option within the browser. However, adding remote management doesn't seem to change the option within the app. Each time I try within the app, I receive, "Something Went Wrong". There was a problem enabling Remote Management, please try again or enable later. Note: If you factor reset your router, you must re-enable remote management. This is a new router, and I've already factor reset it with the same issue. Thanks.
- jkfcb1975Jun 03, 2020Guide
Remote management used to be enabled on mine and worked. But after an App update not long ago it stopped working. I think they just keep quiet until they have a fix instead of owning up to it and saying there's an issue and we'll take care of it ASAP.
- afrenchcheJul 19, 2020Aspirant
I'm having the same issue on my brand new Orbi RBR850 WiFi6 router & satellite. I can go to routerlogin.net and activate the remote management option, but on the Orbi app, the slider moves right (on position) for a brief moment, then slides back to the left (off position) on its own. Remote access is NOT working on the Orbi App!
Thanks for looking into this.
Andrew
- SIVADOct 11, 2020Aspirant
I am having the same issue. HELP PLEASE
