SaintSnow
Nov 03, 2021Follower
Orbi app says no internet connection when there is and it works.
So my phone recently wasn't connecting to the internet through the orbi, while literally every other device worked fine. Just started as of yesterday. I saw that it could be some firmware issue or wh...
Nov 03, 2021Guru - Experienced User
what modem/gateway are you connected to? A lot of times a double nat can have that error/issue.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1 if you're in a double nat.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
