myyrdin
Dec 28, 2020Tutor
Orbi App will not let me assign devices to parental control profiles
Every time I try to set the profile for a device under Parental Controls I receive an error message saying: "Unable to add device to profile". I have rebooted. A few devices work. Most will not le...
myyrdin
Jan 05, 2021Tutor
I deleted the app and reinstalled.
It indicates that there is an issue checking for firmware updates.
App version 2.7.4.1
Router Firmware: V2.7.0.70
myyrdin
Jan 05, 2021Tutor
I manually updated the firmware to 2.7.2.102 and I still have the same issue. The parental controls app is not useable in this state. Please advise.
- myyrdinJan 05, 2021Tutor
Here is a screen shot of the error.
- Christian_RJan 11, 2021NETGEAR Employee Retired
Hello myyrdin,
You may you factory reset your Orbi router and run through the setup assistant again using the Orbi app. We also recently a released a new Orbi app version for iOS (version 2.7.6.3). May you reinstall/update the Orbi app.
Christian
