BrooklynBoy7886
Mar 17, 2024Tutor
Orbi AX4200 (RBR 750)
Trying to figure out why I can no longer control individual devices on the Wifi. Upto a couple of weeks ago I was able to turn on/off devices, set time limits, etc. Can't do it anymore. Not sure what...
Mar 17, 2024Guru - Experienced User
Any changes in FW recently?
How were you controlling your devices? Access Controls? Orbi app or Smart Parental Controls?
- BrooklynBoy7886Mar 17, 2024TutorThrough the Orbi and Device Manager which lists all the devices on the WiFi. It was so easy to hit the pause and I pause button, but now none of the devices respond. Even pausing all the devices doesn't work.
- FURRYe38Mar 17, 2024Guru - Experienced User
Was the Orbi app recently updated?
What platform is the app installed on?
Does this happen if you install Orbi app on a different mobile device?
- BrooklynBoy7886Mar 17, 2024TutorI actually uninstalled the app and then reinstalled it. I have a Pixel Pro 7. I'll have to try it on a different phone.
- BrooklynBoy7886Mar 17, 2024TutorFirmware v7.2.6.21. Don't know when the last firmware update was.
