pablohoney
Apr 15, 2022Luminary
Orbi iOS app issue
Why does my Orbi app connect to remote access when I’m at home as opposed to connecting to the local network? Local access is enabled in the settings for the app. I deleted the app and reinstalled it ...
- Apr 20, 2022
v.24 is out:
Also iOS app is working now for my RBK50:
DarrylMarc
Apr 18, 2022Aspirant
ios 15.4.1
Orbi firmware 2.7.3.22
App version 2.16.0.296
Serial Number: 5M218A5G13730
Model : RBR50
This week the app states unable to connect to router reconnect.
My phone is connected to the network via wifi and all appears to be working.
Network map in the orbo app shows router dot grayed out but three satellites all green
Unable to connect to the router vis desktop. Have rebooted router serveral times but app still states unable to connect to router.
Any help greatly appreciated
pablohoney
Apr 19, 2022Luminary
I’ve found what causes the issue - if you have “Limit IP Address Tracking” turned on in wifi settings you will not be able to access the Orbi app locally.
- FURRYe38Apr 19, 2022Guru - Experienced User
Also the new version of iOS app should help resolve some issues seen.
- DarrylMarcApr 19, 2022Aspirant
Not seen another update released since 2.16.0.296 on April 15th
- pablohoneyApr 19, 2022LuminaryI got an email from support- a fix should be implemented in the next firmware update for the router.
- Alok_Gupta_MNJun 20, 2022Aspirant
Thank you1 this solved my issue with the app that it was not detecting the router. Not sure why the customer service cannot find these simple solutions.
- pablohoneyAug 01, 2022LuminaryIssue now fixed with the latest iOS Orbi app update. Limit IP address tracking can be left on and the Orbi app will connect locally to the router.
- FURRYe38Aug 01, 2022Guru - Experienced User
