pablohoney
Apr 15, 2022Luminary
Orbi iOS app issue
Why does my Orbi app connect to remote access when I’m at home as opposed to connecting to the local network? Local access is enabled in the settings for the app. I deleted the app and reinstalled it ...
- Apr 20, 2022
v.24 is out:
Also iOS app is working now for my RBK50:
pablohoney
Apr 19, 2022Luminary
I’ve found what causes the issue - if you have “Limit IP Address Tracking” turned on in wifi settings you will not be able to access the Orbi app locally.
Apr 19, 2022Guru - Experienced User
Also the new version of iOS app should help resolve some issues seen.
- DarrylMarcApr 19, 2022Aspirant
Not seen another update released since 2.16.0.296 on April 15th
- pablohoneyApr 19, 2022LuminaryI got an email from support- a fix should be implemented in the next firmware update for the router.
- FURRYe38Apr 20, 2022Guru - Experienced User
v.24 is out:
