Art_Masson
Jul 01, 2021Guide
Orbi IOS Application Failing on IOS 15.0 Beta 2
Just for info. I've just upgraded my Iphone to IOS 15.0 Beta 2. Realize this isn't supported, but would like the Orbi development team to be aware. As soon as try to launch the most recent Orbi appl...
- Jul 03, 2021
Solved !! I had to disable "ICloud Private Relay" in WIFI setup. That enabled the Orbi App to "find" the Orbi Network !
Christian_R
Jul 07, 2021NETGEAR Employee Retired
Hello Art_Masson,
Thanks for providing an update to your post as it may possibly help others in the future!
Christian
Art_Masson
Jul 09, 2021Guide
Note that this setting is unique to the Iphone on IOS 15.0 Beta 2. IOS 15.0 Beta 2 on the IPad doesn't have the setting and the Orbi App runs fine.
