Romitelli1
Jan 20, 2020Aspirant
Orbi iOS Remote Management
Orbi Remote Managment isn’t working on my Orbi iOS app. I can connect locally. When I tried to toggle on the enable remote management in the settings on the orbi app I get an error saying something we...
Tindo
Jan 26, 2020Aspirant
I'm having the same problem. It was working fine unit sometime in November last year. No make what we try it says something went wrong. Version number is 2.5.0.108 (the latest).
- chirayudaveFeb 25, 2020Guide
Orbi App remote management just doesn't work. It doesn't toggle at all.
Netgear needs to work on making things easier and not frustratingly difficult.
- Christian_RFeb 27, 2020NETGEAR Employee Retired
Hello chirayudave,
Is you Orbi router in access point mode? Have you tried reinstalling the app? May you also provide the following info as it'll help us understand more:
iOS App Version:
Router Model:
Router Firmware Version:
Thanks,
Christian
- chirayudaveFeb 27, 2020Guide
Orbi Pro Router SRR60 which is connected through wire to multiple devices. I also have its satellite.
SRR60 Firmware Version 2.5.1.106
iOS App version Orbi = 2.4.18.6
I also tried resetting entire Wifi network and re-installing App few times as well.
This was working perfectly fine few days ago. What baffles me is that - why all of a sudden change in app or firmware?
Please let me know if you need more info.
Thanks
