Ikr
Mar 13, 2020Follower
[ORBI] Network map not displaying any devices on iOS
Hello, I can't see any devices connected to my router/ sattelite in the network map on iOS. Works for 2-3 days after factory reset and then always disappears ("No Connected Device Found"). My...
Christian_R
Mar 17, 2020NETGEAR Employee Retired
Hello Ikr,
Welcome to the community! I'd like for our support team to look into this further for you. May you send me a private message with your contact info and serial number.
Thanks,
Christian
Rloving
Mar 23, 2020Aspirant
I have the exact same issue. Firmware 2518
- Christian_RMar 25, 2020NETGEAR Employee Retired
Hi Rloving,
May you try reinstalling the Orbi app and performing a factory reset on the Orbi units.
Thanks,Christian
