guitarman555
Jan 16, 2023Tutor
Orbi Not Found - RBKE963
Hello - I'm still having trouble with my new Orbi Unit. I never did resolve all of my problems with it - but it was working well enough until this morning. It quit working, so I tried to reset it and...
- Jan 17, 2023
There was a previous wi fi system installed yes. It was an older version of the Orbi. I plugged it into the same isp. I used the same SSID and password as well.
I set it up using the orbi app on my iPhone.
Last night, after getting home from work, I decided to try one more time to set it up. I reset the orbi's again with the paper clip.This time however, I decided to try something different, I deleted the app from my phone as well, and then reinstalled it. That enabled a completely fresh setup as far as I know.
And it worked, my wi fi is back (for now anyway)
That must have been what that gateway message was about. The app needed to be deleted too, in order to have a completely fresh setup. Something to keep in mind for the future.
Now I see how things go in the next few days, if everything keeps working.
CrimpOn
Jan 16, 2023Guru - Experienced User
When a Factory Reset* is performed on a router, all user settings are erased. (Gone) The WiFi name & password will be what is printed on the product label. The web browser interface credentials will be "admin" and "password".
* Holding a sharp object, such as the end of a paperclip, in the tiny "Reset" hole next to the power switch until the power LED turns amber and begins to flash.
It would help to know how this new system was installed:
- There was a previous WiFi system that has been removed and the Orbi plugged in to the same ISP equipment?
- The Orbi system was configured with the same (exact) WiFi name and password as the previous equipment?
or
- There was not a customer owned WiFi system and the Orbi was connected to the ISP WiFi router and given the same WiFi name and password as the ISP WiFi router?
How the Orbi was configured (using the web interface* or the Orbi 'app')?
*See page 23 of the user manual: https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf
- guitarman555Jan 17, 2023Tutor
