guitarman555's avatar
Jan 16, 2023
Orbi Not Found - RBKE963
Hello - I'm still having trouble with my new Orbi Unit. I never did resolve all of my problems with it - but it was working well enough until this morning. It quit working, so I tried to reset it and...
  • guitarman555's avatar
    guitarman555
    Jan 17, 2023
    There was a previous wi fi system installed yes. It was an older version of the Orbi. I plugged it into the same isp. I used the same SSID and password as well.
    I set it up using the orbi app on my iPhone.
    Last night, after getting home from work, I decided to try one more time to set it up. I reset the orbi's again with the paper clip.This time however, I decided to try something different, I deleted the app from my phone as well, and then reinstalled it. That enabled a completely fresh setup as far as I know.
    And it worked, my wi fi is back (for now anyway)
    That must have been what that gateway message was about. The app needed to be deleted too, in order to have a completely fresh setup. Something to keep in mind for the future.
    Now I see how things go in the next few days, if everything keeps working.
