XBond
Jan 20, 2021Apprentice
ORBI now showing offline devices too
I was updated to the latest fw this morning. Now the ORBI app under Network Map, lists both online and offline devices which is kind of a pain, since I don’t need/care to see offline devices. It...
Christian_R
Jan 27, 2021NETGEAR Employee Retired
Hi XBond,
Thanks for getting back with an update. May you factory reset your router and run through the setup assistant again using the Orbi app.
Christian
XBond
Jan 27, 2021Apprentice
Got a call from Netgear Level 2 support yesterday. This seems like a feature change in the app. Being escalated to the engineering team. There is nothing wrong with the app it the new behavior makes it harder (and more annoying) to navigate in the app.
Also, doing a factory reset just can’t be the answer to everything - my two cents.
- ToddgarnandJul 21, 2021InitiateMy concern is, are these offline devices tying up IP addresses eventually leading to no available IPs as devices pull new leases, especially with the roll out of private WiFi-addresses. And for someone whom has static routes, IP reservations, and V-lans setup I refuse to accept a factory reset as an acceptable resolution and I certainly have neither the time nor desire to sit here and manually remove/delete each device one by one. Industry standard for a DHCP lease is 72 hours, considering it would appear there is no expiration for leases in the Orbi system I would think that to be a reasonable place for the Engineering and Development team to start
- CrimpOnJul 22, 2021Guru - Experienced User
I, also, was surprised to see over 100 devices in the Orbi "app", which I verified by opening the Orbi web interface to the Advanced Tab, Security, Access Control. There is a table, "Allowed Devices not currently connected to the network." Oh, my. Every device that had ever connected to the Orbi was listed.
This makes sense in the context of Access Control. If the user enabled access control and specifies "Block New Devices from Connecting", then the Orbi needs to have a record of devices which have been allowed to connect. This does not tie up IP addresses in the DHCP pool. All it does is remember "This device is allowed."
In my case, I have Access Control disabled. (I find it a distraction.) So, I got rid of all these entries. If one of these devices comes back some day and tries to connect with the 25 character Orbi WiFi password, I'm fine with that.
If the concern is tying up IP addresses, I believe it is not the case.
