HatchiNZ
Jan 31, 2019Aspirant
Orbi pausing devices
Ok, I have been having major troubles with my setup recently.
I made the mistake of enabling Circle and attempting to set things up for the kids and the adults and associated devices, but soon ...
DexterJB
Feb 04, 2019NETGEAR Moderator
Hi HatchiNZ,
Welcome to the community!
1. What is the firmware version of your Orbi?
2. Have you tried resetting the device back to factory defaults?
Dexter
Community Team
- DexterJBFeb 07, 2019NETGEAR Moderator
Hi HatchiNZ,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- HatchiNZFeb 07, 2019Aspirant
yup, the app (or router) seems to be still randomly Pause devices on the network. And yes I have installed all the latest updates on Orbi and the devices
- DexterJBFeb 10, 2019NETGEAR Moderator
- KtarbelloFeb 22, 2019AspirantI’ve got the same problem. Same history of adding circle ⭕️ then deleting. Annoying. Need to return and get google.
