Intmedhead8
Sep 11, 2020Tutor
Orbi RBK 853 speed test not working
Speed test is no longer working. States connection failure. I have rebooted and uninstalled and re-installed my APP. No luck. It was as working when I first got my mesh in June and now that my free Ne...
- Sep 24, 2020I was finally able to speak to a Netgear support rep, Rose. The delay was from my end, not theirs. She performed a factory reset remotely on my router, and I went through the steps to set up a new router. The reset was initiated from within the router web page (I don’t know exactly where on the page the reset was accessible since I was not doing it, but to be clear, it was not via the app). After the router had restarted and I finished the installation process, the SpeedTest via the app worked. Considering that the app worked for me previously and then stopped, much like what has happened to others, I’m cautiously optimistic that this is a permanent fix. But I have to say that Rose was great and I’m back in business.
Intmedhead8
Sep 14, 2020Tutor
Apple iPhone X.
Orbi version 2.6.2.9
firmware version V3.2.16.6
Cshartma
Sep 15, 2020Guide
I have the same problem. Speedtest in the app and on the router’s web interface have ceased to work after a firmware upgrade. I’ve vlcalled netgear support 4 times - each time on hold for 1.5 hours. None of their suggestions helped. They are not only incompetent but also Poorly managed. This is the worse customer experience I’ve had on any product.
