jhermsmeyer
Jul 29, 2020Guide
Orbi (RBK852) Pause Not Working
30+ active devices rock solid stable for over a month with significant usage. decent whole house coverage. crazy fast paired with att fiber. but... I can't get the pause feature to work at all. whe...
Christian_R
Aug 04, 2020NETGEAR Employee Retired
Hi jhermsmeyer,
May you update to the latest firmware version below and reinstall the Orbi app. Please let me know how it turns out.
https://kb.netgear.com/000062077/RBR850-RBS850-Firmware-Version-3-2-15-32-Hot-Fix
Christian
jhermsmeyer
Aug 05, 2020Guide
I updated the satelite and router firmware versions manually to version: v3.2.15.32_1.3.25
I also deleted and reinstalled the orbi app on my iphone.
I did not lose any functionality (everything that worked before still works) and things are stable so far, but the pause feature still does not work from the orbi app.
I also tried blocking access using the access control feature on the routers webpage (via laptop).
that also seems to have no effect...
- Christian_RAug 05, 2020NETGEAR Employee Retired
Hi jhermsmeyer,
Thanks for confirming. I'd like for our support team to reach out for further assistance. If you wish to be contacted, please provide me with your email, phone, and serial number in a private message.
Christian
